Easy hands-on install of new foam bumpstops January 14, 2008 By:
Dan Spalinger/Team Xterra Racing
Enhanced Vehicle Suspension bumpstops from Daystar are designed to be installed on the shaft of ANY shock, enhancing its performance, softening compression and preventing hard impacts.  Bilstein OE replacement shocks for your Chevy October 9, 2007 By:
Jaime Hernandez
Check out our helpful "How to" guide on our writer's own Chevy Tahoe using Bilstein Shocks!  Lorenz Industries Bilstein 5100 Suspension System October 1, 2007 By:
Dean Waters
As we roll over 25,000 miles on our Dodge Ram 3500 Mega Cab, most of it hauling or towing, we have finally chosen our suspension system. After much research and feedback from other Ram owners we have turned to Lorenz Industries.  June 6, 2007 By:
Manny MacMillan
"Crazy mad flex!...the best $300 mod any H3 driver could ever make."  Installing Superlift's 6" Suspension System June 1, 2007 By:
Jarred Meyer
After our trip to Flat Nasty about a month ago we determined that installing a body lift and forcing the largest tires possible did not provide satisfactory ground clearance. For obvious reasons it appeared that we were in serious need of a suspension lift.  Installing a Body Lift on our 1993 Chevy K1500 March 1, 2007 By:
Jarred Meyer
In this our most recent modification we are dealing with the issue of wheel well clearance. After looking at a few different possibilities we determined that for the size tire we will be trying to fit (either a 33 or 35” tire) it would be most cost-effective to purchase a 3" body lift.  King Coil-overs Install on Ford F-150 March 1, 2007 By:
Craig Perronne
Suspension upgrades usually conjure up nightmares of an assortment of A-arms, brackets and spindles along with plenty of cutting and welding. After enough busted knuckles, burnt flesh, cursing and sweat, the new suspension is in place and finally ready for use. However one is usually broke from buying the suspension and too tired from the install to use it.  Ford F-350 Super Duty gets a lift November 1, 2006 By:
Jaime Hernández
With desert season just around the corner, Rick knew it was time to get his Ford Super Duty ready to tow in style. He wanted to give his F-350 a lift so he could fit bigger tires and give it an aggressive look. The tricky part was to keep O.E. handling, and have it be able to tow  Welding in our Long Travel Suspension Kit August 1, 2006 By:
Dean Waters
In Part III we bring in an expert to help us weld in our Total Chaos long travel suspension kit. Our Toyota Pickup is starting to look more like a REAL prerunner.......
Untitled Document| Sponsored Links | Need Gas Mileage & Power?- Free flowing performance exhaust can increase gas mileage and increase power. We can all benefit from increased mileage and increased horsepower & torque improves towing, mud-slinging and the ability to turn those larger tires you put on your truck. See what Flowtech Exhaust has for your gas or diesel truck. |
Stickers, stickers, stickers!- You don't have to beg - you can get them for free! Just simply register and Off-Road.com will send you stickers from our participating companies. It's free and easy, so slap them on your ride, house or friends. Click here to register and get sticky... |
Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. |
ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. |
In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! |
